gotriceboy05 Posted January 27, 2004 Share Posted January 27, 2004 a friend of mine is selling a msd ignition for 50...and i was wondering if there worth the performance alone...and also wonder if i need to get better spark plugs,etc with it?? Link to comment Share on other sites More sharing options...
guygettnby Posted April 12, 2004 Share Posted April 12, 2004 what kinda MSD ignition is it? is it a aftermarket coil? or is it an actual msd ignition box? if it is an actual ignition box then you need an aftermarket coil like the blaster ss coil pack, and if that is what it is then you cant use platinum plugs . i recomend doing it all at once if you upgrade the ignition sytem. yes it does make a difference in power but not very much and most of it is at high RPM's Link to comment Share on other sites More sharing options...
