702enigma Posted April 9, 2020 Share Posted April 9, 2020 I have a 2008 honda odyssey touring with nav. Im getting code U0155 when I hook up my Obd2 scanner.I also have a check transmission and check airbag system notification. Car flashes check engine light 4 or 5 times then goes away on startup.Car runs and drives just fine.instrument cluster functions normally except for not showing what gear i am in but shows im in park on start up then when CEL comes on it dissapears.Im I ran a multimeeter on my OBD2 port on pins 14 and 6 and got 56 ohms i also ran pin 16 to 4 and 5 and got my battery volatage if this help.on my scan tool it does show my vin correctly if thats any useful information Update- I ran a different setting on my obd2 scanner and i get a code for just about every sensor for the engine and transmission and they all say test not completed during this operation cycle Link to comment Share on other sites More sharing options...
Mike4393 Posted April 15, 2021 Share Posted April 15, 2021 Hello Might be better to have your original part repaired at https://www.upfix.com Here is the service linkhttps://www.upfix.com/product-category/repair-return/engine-control-repair/ Link to comment Share on other sites More sharing options...
