joshsmommy642 Posted December 1, 2019 Share Posted December 1, 2019 I have a 2005 honda pilot. I noticed it was making a noise, checked the fluids and the power steering fluid was low. After some looking it was determined that the pressure hose was leaking right at the top where it was visible that fluid was coming out when you turn the wheel back and forth. I took it a mechanic and had him change the pressure hose. Well its still leaking, not a large amount at a time but enough where Im having to put more fluid in every few days. The fluid is leaking on the driver side, Im not mechanically inclinded at all, any suggestions on what to check next? Ive only read about the rack and pinion and that sounds like it'll be a very expensive repair if it ends up being the issue. Thanks guys! Link to comment Share on other sites More sharing options...
