5-speed Posted August 30, 2019 Share Posted August 30, 2019 Installed New plugs.. Replaced the fuel filter and pump, ignition switch, crankshaft sensor, replaced the MAF sensor and the idle control sensor. Put new throttle body on cleand all that. Cleaned fuel rail and injectors. Checked all batt connections and grounds. Connected the rear O2 sensor on exaust. Valve adjustments. Checked the timing. Reset the computer. Let it run for 10 mins for cpu to learn new changes and everythin.... Still dien at random times!! any ideas? Link to comment Share on other sites More sharing options...
Jenika Posted August 31, 2019 Share Posted August 31, 2019 When it won’t start are you getting a spark at the spark plug? If not maybe one of the distributor components could be to blame? The ignition control module, coil or cap and rotor could all possibly cause no spark and might be worth testing. Also the main relay (PGM-FI) seems to be a common issue. My sisters crv is currently doing the same thing so if we find a solution tomorrow I’ll let you know what worked for us. Good luck! Link to comment Share on other sites More sharing options...
5-speed Posted September 1, 2019 Author Share Posted September 1, 2019 Just replaced the main relay that's up under on the passenger side glove box seems to be doing the trick I took the old one apart and on the inside on the circuit board looks like the number two spot was burnt that goes from the ground to the ignition also you could smell it Link to comment Share on other sites More sharing options...
Josiah T. Posted October 18, 2019 Share Posted October 18, 2019 I just bought as 1993 Honda Civic (coupe), and have spent hours and countless efforts in fixing my car from stalling in the middle of nowhere. I replaced the Spark plugs, spark wires, and the ignition coils so far. Also, i'm about to replace the distributor rotor and cap... but am waiting cause i think it might be a fuel issue. I've very baffled as to what exactly it may be because it could be many many things. please help... -Josiah Link to comment Share on other sites More sharing options...
