5-speed Posted August 30, 2019 Share Posted August 30, 2019 Installed New plugs.. Replaced the fuel filter and pump, ignition switch, crankshaft sensor, replaced the MAF sensor and the idle control sensor. Put new throttle body on cleand all that. Cleaned fuel rail and injectors. Checked all batt connections and grounds. Connected the rear O2 sensor on exaust. Valve adjustments. Checked the timing. Reset the computer. Let it run for 10 mins for cpu to learn new changes and everythin.... Still dien at random times!! any ideas? Link to comment Share on other sites More sharing options...
