Turn signals
Strahan
Hi.  I have a 93 del Sol S and neither the turn signals nor hazards work.  I replaced the flasher relay, but to no avail.  I dug up my del Sol tech bible and looked up turn signal diagnostics.  It had me check a few fuses (fine) and then had me diagnose the six pin connector.  Shorting 1 to 2 did not illuminate the right lights, nor did shorting 1 to 4 illuminate the left.  Also I noticed that if you meter #5, it is open until you hit either the hazard button or turn on the right turn signal.  That's the way it's supposed to work.  However, metering #3 shows it hot all the time no matter what you are doing.  The tech book says what to do if it doesn't go hot, but not what to do if it's always hot.  Any ideas?
