SoSlowCivic Posted December 27, 2018 Share Posted December 27, 2018 What’s up forum, I recently ran into some clutch problems and replaced my clutch slave and attempted to bleed it. When bleeding it I noticed, when having someone press the clutch, the clutch fork is not moving. I took the clutch slave back off and there’s a lot of play in the fork. Should there be tons of play in the fork? Does the fork need replacing or could it be the clutch release bearing? The clutch peddle has no resistance and when pressed goes all the way to the floor. Link to comment Share on other sites More sharing options...
