tex rsx Posted May 10, 2015 Posted May 10, 2015 I recently purchased a 2002 RSX type s from an auction. the car turns over but has no spark, no power to obd either so I am unable to communicate with ecu. The ecu fuse in engine bay is good. is there another fuse I should check? looking at the harness under the steering wheel I can tell that previous owner cut into the wiring for some type of remote start that may have shorted out causing a unknown fuse to blow or causing failure in ecu. I am at a stalemate Please help!
