ActualCro Posted April 7, 2015 Share Posted April 7, 2015 So I had to get a new door panel today. When detaching the panel I ended up hitting the power lock wire and it broke. So it doesn't lock/unlock the doors anymore. 2000 Honda Ex coupe. If that helps. Is there a way I can buy a new one (The thing that holds the wires, then connects to the lock)? Thanks in advance. Link to comment Share on other sites More sharing options...
airjordan223 Posted April 7, 2015 Share Posted April 7, 2015 Can't you just reconnect the wire? If not, you should be able to get one at a junk yard or pick and pull pretty easily. Or if you want new try Majestic Honda. Link to comment Share on other sites More sharing options...
