G23
Mitechautomotive
Ok so I have a prelude with a h22a4 and I spun a bearing. I have a f23a1 block with low miles and have read a lot about doing the G23 switch over. Make sure I'm right you gotta block off 2 oil ports, crank gear swap, water pump gear swap, motor mount on driver side, and what else? Also what head gasket and pistons work best with this setup? I've heard a lot of people say B20 pistons but others say the f23a1 pistons for lower compression cause I am doing a turbo setup after the swap
