'98 - '-02 Accord 4-cyl engine pull question
Iapetus
Anyone every tried to pull the engine out of a '98 - '02 Accord (4 cyl) without removing the transmission? I can't separate the two and I believe I've removed all the brackets and bolts connecting them. The dowel pins between the engine and transmission housing could be stuck I supposed. Violent shaking doesn't seem to work - neither does a 2-foot long pry bar. Any thoughts?
You missed a bolt.
Find a diagram, count what your supposed to have, review what you've removed, then remove what's left.
The one that always gets me is buried under the thermostat housing, kinda under the distributor and behind some wires.
