Exia Posted January 27, 2013 Share Posted January 27, 2013 Ok, I have been every where, trying to get help with this.. I recently got a Del Sol built out the ying yang.. a few days ago, one of the linkage bars broke.. Apparently the PO had welded a extension and it was a very poor job.. It has the JDM B18CR swap What I need is the correct length measurement from tip to tip from a correct linkage.. and a measurement for the bend to allow the shifter to go in the car.. This is not the bottom linkage... This is the I guess the stabilizer bar? its the bar that holds the shifter if that helps.. Before it gets suggested, I do not have the funds to buy the correct linkage right now, I just spent alot turning this car back into a DD, the PO was turning it into a track car.. So I just need 2 measurements nothing more .. Thanks Link to comment Share on other sites More sharing options...
Exia Posted January 29, 2013 Author Share Posted January 29, 2013 Ok.................. Since no one wants to help, with that question, ( seems to be a trend on ALL honda forums ) Can some one tell me, what that bar is accually for? Link to comment Share on other sites More sharing options...
