jwells0504 Posted November 16, 2012 Share Posted November 16, 2012 Hello. So I just bought a brand new Honda civic coupe 2012 model. It's my first car and it took me some time to save the money I needed for my massive down payment. After driving it for nearly a week I noticed a few things that just bug me and I was hoping for someone to help. I guess I'll just get right to it then. So the first issue I have is my fuel economy. The cars specs say it gets 30 on city and 40 on highway and consumer reports said they actually ended up with a little better but the onboard computer says I only get around 24 average. I can't figure out why, I drive economically, I'm not in any stop and go traffic, I just can't figure out why. Second is the gear changing seems like its a little rough whenever I put it from park to drive, feels like I pressed the gas as soon as I did it when I didn't and the car just wants to take off. Third is the feedback I get from the engine whenever I press or let go of the gas peddle, it feels like as soon as I let it go and engine jumps, same thing when I press the gas too. Also the plastic doors vibrate loudly whenever a certain tone of bass is played through the speakers, not played excessively loud just deep base. These issues bother me quite a bit and I was hoping for someone to put my mind to ease. Any help is much appreciated. Link to comment Share on other sites More sharing options...
James Matteu Posted November 16, 2012 Share Posted November 16, 2012 1. Your engine is designed for performance with a secondary valve profile for economy that only comes into play at highway cruising speeds. You can help out by making sure spark plug, air filter, and oil maintenances are all up to date. In the end, its your foot that will have the largest impact on fuel economy, and it has little to do with traffic: how fast you accelerate and how high the RPMs get play a larger role in fuel economy that anything else. 2. This is normal when the motor is cool, there is a Fast Idle Thermo Valve responsible for raising idle speed to prevent stalling and lower tailpipe emissions (the catalytic converter does not work when cold). If this is a persistent condition regardless of engine temp, you may want to reset the ECU to help it adjust to the fuel you're using: you may very well be using a higher octane than the previous owner. 3. See #2. 4. Check to be sure the panels are secured with all their tabs and screws. A loose panel will vibrate easily. Otherwise, you will have to remove the door panels and install foam backing as support. Link to comment Share on other sites More sharing options...
TheReachFreaks Posted November 20, 2012 Share Posted November 20, 2012 This thread should help you, http://www.hondachat.com/showthread.php?t=IDBvgx4d8rFOpBe2k Link to comment Share on other sites More sharing options...
thaicivic Posted November 23, 2012 Share Posted November 23, 2012 And congrats on your Civic purchase. Even though you're having small issues it'll serve you well for a long time. Link to comment Share on other sites More sharing options...
