loweredCD5 Posted October 28, 2012 Share Posted October 28, 2012 I recently blew the head on my f22b2 and i was considering doing a Frankenstein swap for a while. But i need my car now so i was considering doing the first half of the swap on my car by putting a gsr head on my f22 block. Just wanted to hear everyones thoughts maybe opinions and advice and or points and things to put into consideration. Link to comment Share on other sites More sharing options...
James Matteu Posted October 28, 2012 Share Posted October 28, 2012 A B series GSR? Doesn't line up. H series head can be put on the F series block but your compression should drop and your horsepower along with it. The setup is designed for boost, a search on G22 will tell you more. Plan on doing an H22 swap, forget swapping heads to your F-block. If you're set on keeping the F-series motor, then boost it. Swapping heads has been done, you wouldn't be trying anything new or be doing something unique; but that head swap has a very specific purpose. Link to comment Share on other sites More sharing options...
