lewia025 Posted September 27, 2012 Share Posted September 27, 2012 I have a 96 that I bench tested the starter and replaced the main relay. despite the starter passing the test twice and having the relay replaced, it still Won't start despite having a fully charged battery. I hear a click from the engine compartment, but nothing more. Please help. Link to comment Share on other sites More sharing options...
h22delslo Posted October 16, 2012 Share Posted October 16, 2012 try to test the signal wire to see if you have signal when you turn the key use can do this with a volt meter if you do have signal there is a loose conection some where in the system try cleaning all your conections and looking for a bad spot in the main battery wire that goes to the starter. Link to comment Share on other sites More sharing options...
