b2manufacturing Posted March 8, 2012 Share Posted March 8, 2012 Hi, I'm new to this site and forums in general. I have a 2000 civic EX, I'm about to do a k swap but before a make a big mistake and ge the wrong K motor, I need to figure out if it can pass emissions, I want the JDM K20A but I'll sacrifice the 20hp and go with a USDM K20A2 or K20Z1 and swap a JDM DC5 LSD 6 speed transmission on it if it means being legal. 1. Has anyone swapped a JDM K20A RSX DC5 Type-R or Civic K20A EP3 Type-R, motor into an EK civic before? 2. what does it take to pass emissions. I have checked local Oregon DEQ Emissions, and it's not very specific other than the motor and chassis must have the same manufacturer and you can't put an older year engine into a newer year vehicle. So, as far as that goes I'm good. I'm just concerned that the JDM ECU wont Jive with the OBD2 I don't want a bunch of flags popping up when they plug it in. I've done two B16 USDM swaps, and one jdm B18C GSR swap, about 10-12 years ago, I'm just now getting back into it and a little rusty, so if u have any valuable experience in K-Swaps I'd apreciate input. I will be using Hybrid Racing's swap parts including; Motor mounts HR 2.9 axels HR K-Swap clutch kit OEM RSX Type-S p/s pump OEM 96 civic A/C condenser OEM 96 civic throttle cable OEM 93 civic si sub-frame HR conversion harness HR Adj speed converter HR K-swap grounding kit HR Recurculating fuel line kit HR bolt-in short shift kit HR performance shift cables HR half size radiator HR silicone K-Swap radiator hoses HR K-Swap A/C kit HR K-Swap Power Steering kit HR K-swap Header and much more etc..... If you have done this swap, or, if you are familiar with jdm K-Swap, I'd greatly apreciate your input. Thx B2 Link to comment Share on other sites More sharing options...
b2manufacturing Posted March 9, 2012 Author Share Posted March 9, 2012 Well, I got the answer... yes it will pass emissions if you use the EKs wideband O2 sensors, or if you are lucky enough to get a JDM motor with the O2 sensors Link to comment Share on other sites More sharing options...
