Brad Hartwell Posted March 3, 2011 Share Posted March 3, 2011 Hi, While checking fuses on the passenger side of the car, I removed and replaced several fuses to determine working or not. I found all fuses to be in good working order except #14 ABS motor check. I put a new one in place but still no power there. I test drove the car and now the ABS light on the dash is on. Did I cause that by remove/replace a fuse? The light was not on prior to pulling any fuses. Thanks for any help. Brad Link to comment Share on other sites More sharing options...
