scarecrow0529 Posted January 31, 2011 Share Posted January 31, 2011 when i turn the key to get it started it just goes dead lights and all. it started when i pushed the clutch down to start it it just ckicked and buzzed then dead. eventually i did get it started and just to check i turned on everything and it bogged down alot but didnt die. it s an 89 crx with standard 1.5 engine. the engine ground is lookin pretty corroded but i tried to change a month ago and it wouldnt stay runnin put the old one back on and ran fine until now. Link to comment Share on other sites More sharing options...
Humphries Posted February 3, 2011 Share Posted February 3, 2011 check your starter. Link to comment Share on other sites More sharing options...
scarecrow0529 Posted February 3, 2011 Author Share Posted February 3, 2011 check your starter. it was the negative cable for the battery it was loose where it connects just under the battery pan. all is good so far. thanks. Link to comment Share on other sites More sharing options...
