zei Posted November 29, 2010 Share Posted November 29, 2010 Hi, My car recently overheated and when they checked the possible culprit would be the head gasket. Their suggestion was to replace the entire engine. Is there a way of fixing the head gasket issue without having to replace the entire engine? I need your advice. Symptoms - Car overheated (once) - continuous stream of bubbles observed in the overflow tank - white smoke during start up but when the engine is on it's right temp, white smoke disappears - no trace of oil in the overflow tank I hope a fellow honda man can help me with this issue. Thanks in advance! Link to comment Share on other sites More sharing options...
airjordan223 Posted November 29, 2010 Share Posted November 29, 2010 You only need to make one of these threads. Link to comment Share on other sites More sharing options...
