Escape-performance Posted November 28, 2010 Share Posted November 28, 2010 I have Bee R launch control, dual rev limiter. It has high and a low adjustable rev limiters. The high limiter is adjustable in 500rpm increments, but will not allow the engine to rev past any existing limiters. The low limiter is also adjustable in 500rpm increments. It is set in the 3k-5krpm range depending on your preference. The low limiter is activated when the clutch (or brake for automatics) is depressed. This allows the driver to hold the gas to the floor at the start line without maxing the rpms out. It also allows for flat shifting, letting the driver shift gears without letting off the throttle. This works because when the clutch is pressed to shift the limiter is dropped to the low limiter setting. Unlike factory limiters that cut fuel the bee r limiters work by "scrambling" the ignition signal. In essences retarding the ignition to the point where in is ineffective. Since the ignition and not the fuel is cut his often creates the flame shooting exhaust they are know for. It also means that I do not recommend using these on cars with catalytic converters. The fuel going through the exhaust will most likely damage them. I will also note that when activated these units are VERY loud, sounds like shot guns going off. There is a gain control that allows you to adjust how "hard" the limiter hits, basically controls the time between limiter hits changing how many times it bounces a second. Very easy to install, 5 wires. Power, ground, clutch pedal, crank signal, ignition signal. Thanks Link to comment Share on other sites More sharing options...
Escape-performance Posted November 28, 2010 Author Share Posted November 28, 2010 oops forgot the price, $220 shipped to the lower 48 Engines listed on the instructions, B16A, D15B, B16B, B18C, B20A, F22B, F22A, H22A, F22A, F22B. Link to comment Share on other sites More sharing options...
civic_ek_buddy Posted December 14, 2010 Share Posted December 14, 2010 hi m8, is it still available? if so,send ma a email to choppery2k@msn.com thanx Link to comment Share on other sites More sharing options...
Escape-performance Posted January 13, 2011 Author Share Posted January 13, 2011 Still have a couple left. Link to comment Share on other sites More sharing options...
xxipsxx Posted January 27, 2011 Share Posted January 27, 2011 free bump! Link to comment Share on other sites More sharing options...
Escape-performance Posted February 12, 2011 Author Share Posted February 12, 2011 still for sale Link to comment Share on other sites More sharing options...
Escape-performance Posted April 2, 2011 Author Share Posted April 2, 2011 Just got some more of these units in. Link to comment Share on other sites More sharing options...
