Interior Lights
Sean2012
Posted
I want to add some interior LEDs around my new stereo. i can install them and everything but how do i plug them in. do i plug it into the fuse box somewhere? thanks for any help.
Posted
Depends how you want them.
If you want them always on, you can run them to a fuse for something that is on with acc mode.
Or you can wire them to a switch.
Posted
ok well this is what i would like to do. install them to the fuse box and put a switch on it that ill buy can i do that? and where would i plug them into the fuse box? <thats my biggest question
Posted
Ok so what you're going to do is buy a fuse adder like this:
and also a switch of your choice.
Your LEDs should have two wires, one for power one for ground. You want to find a good ground for all your LEDs, this can be a bolt with a metal/metal contact. If there is some paint, just sand it off.
Then wire the power wire for the LEDs to the switch, and the other prong on the switch goes to the fuse adder.
Sort of like this:
Depending on what type of LEDs you have and how many will depend on what size fuse you want to tap into, but typically 5 is fine.
Your fuse box is most likely located on the drivers side above the dead pedal.
Posted
Sort of like this:
Okay thanks for all the help. Let me just make sure im right...
So i get the adapter into the number 5 spot
Then the ground wire i just connect it to any bolt on the car? srry i dont understand that
Posted
Nope, not the number 5 spot, you want to plug into a spot that has a 5 amp fuse.
See those numbers on the fuses, find one that has the number 5 on it, take it out, plug that 5 amp fuse into the adapter you buy, then plug the adapter into the spot where the fuse was.
As for the ground, it can't be any bolt, just one that is bolted to metal. You may want to pull up your carpet a little bit to find one. If you have a voltmeter you can check to see if the bolt is grounded or not.
I hope that helps, let me know if you're still unclear on anything.
Posted
Alight Thanks Alot im pretty sure i get it now. Ill set it up sometime today and maybe put some pics up later. Thanks!
