racerrick Posted October 24, 2010 Share Posted October 24, 2010 ok here we go 92 prelude with a jdm motor and a us harness. ended up with 2 extra wire connectors.1 is green 2 wire in the dist harness.the 2nd is on the pass strut tower and is gray 2 wire.(see pics) the fans do not come on and the check engine light is on.is there a way to pull codes with out a scan tool? does any one have a vacuum hose routing chart? thanks for any help you can give us Link to comment Share on other sites More sharing options...
