Chy Posted October 17, 2010 Share Posted October 17, 2010 2004. Blower motor stopped working. 1. check under the hood fuses and inside the car fuses= all ok. 2. bypassed the resistor and gave full power to the motor blower = went to FULL SPEED, checked out ok. My conclusion: Replaced the resistor: cost = 89 bucks. That same day my blower motor crapped out again??!?? Am i missing something?? anyone been thru this before?? sighs*** Quote Link to comment Share on other sites More sharing options...
kiwi87 Posted October 17, 2010 Share Posted October 17, 2010 it is the blower motor itself....it is most likely the resistors and all that happy crap inside it......a good way to check is if you have a multimeter check the resistance and then run a pair of jumper wires straight the the motor and see what happens Quote Link to comment Share on other sites More sharing options...
Chy Posted October 17, 2010 Author Share Posted October 17, 2010 Thanks Kiwi87 Is there a minimum for resistance? I did replace the resistor and it worked. But next time i turned it on, my fan motor stopped working again. All in the same day too. frustrating. I'll get my multi-meter and check the voltage and post my results. chy Quote Link to comment Share on other sites More sharing options...
