d15b1 swaped to d16z6
i have a 1991 honda civic (base)
it has the d15b1 with four speed
kinda on a budget
and i want to swap it for a d16z6 with five speed
and before i start i have a few questions
i know i have to get the d16z6 engine+tranny, ecu, wiring harness etc. but:
1 will the tranny fit with out mods or will i need to change something for the five speed
2 will i need the d16z6 motor mounts or will it line up with the old ones
3 will it fit under the stock hood
4 does the d16z6 like turbos (might go turbo someday)
5 will the axles fit with the 91 spindle or do i have to change to the 92-95 spindle
6 will i have the same specs as the stock civics or will the weight make it more
7 what HP and torque can i pull out of it
8 what would be the CR of it
9 is a high CR good or bad
well i think thats all the questions
thanks for the help
  • 1 month later...
1. you cant use the 92 up trannys in your car. you need a cable clutch tranny. they are cheap and also come in 5 spds.
2. you will need to take all the mounts off the d15 and put them on the d16.
3. yes , lol.
4. yes , lol
5. the axles are all the same for d series. reuse the ones that come out.
6. same weight pretty much.
7. not much , its a d series
8. since its a stock engine it will have stock compression ratio.
