massasshadows Posted August 27, 2010 Share Posted August 27, 2010 i have '00 civic dx and i had this code so i swapped out the sensor, the one that is behind the crankshaft pulley/ within the timing belt housing. took it to a mechanic and he said that because it was an after market sensor from Kregan (O'Reily) then it might be that it was just a crappy one, and i should get a certified honda sensor. any possibility in that? also i was poking around and i tested the sensor wires and they seemed to be okay (if i was doing it right), but i wasn't able to get inside the distributor. i got the outter casing off but there was another casing in the way w/ a lil wheel type deal in the way and i didn't know how to remove it. as far as looks go, it was all very clean. i checked all other wires as best i could to see if any were damaged and it all looked fine. it's starting to stall almost everytime i come to a complete stop now. Quote Link to comment Share on other sites More sharing options...
massasshadows Posted August 27, 2010 Author Share Posted August 27, 2010 even though it's sorta implied, i forgot to mention that the problem still occurs even though i swapped the sensor. Quote Link to comment Share on other sites More sharing options...
