93 civic hatch Posted July 10, 2010 Share Posted July 10, 2010 Anybody having trouble with their A/C compressor shutting off once in a while on their 01-05 civic....try changing the thermal protector ....then remove the clutch and clean up the back with a die grinder.....there is alot of rust on the back and on the compressor pulley face that enlarges the air gap. reinstall the clutch and re-check the gap...spec is .010-.015.......B careful not to lose the tiny shim on the shaft that the clutch slides off of...it probably wont come off ...Just keep it in mind.....easy to do ..... Link to comment Share on other sites More sharing options...
