98 honda crv timing
HI to all,
I have had to replace my distributor on my 98 honda crv 2.0 as the coil exciter went bad,
I need to set the timing and not sure what it is and if anything needs to be disconnected before setting the timing .
thanks for any help.
the timing on your distributor ??
thankyou for your reply, not the distributor, the timing in which you move the distributor with engine running ,
it would be the base timing, as the rest is all controlled by the computer , etc.
i did find the answer and set the timing, thanks .
