dally41888 Posted March 1, 2010 Share Posted March 1, 2010 i have an 03 accord ex and the heat just stopped switching directions. the air blows out just through the front face vents but will not switch when the buttons change. i heard it possible could be the mode motor but was unsure of its location or if there is a certain fuse that may be blown or a different reason why it stopped changing direction. if anyone has some insight on this i would greatly appreciate it. Link to comment Share on other sites More sharing options...
James Matteu Posted March 2, 2010 Share Posted March 2, 2010 I am not an expert by any means, but newer Accords should be on a Multiplexer System that can fritz out and need reseting. Try looking up more info on that. Link to comment Share on other sites More sharing options...
airjordan223 Posted March 2, 2010 Share Posted March 2, 2010 Check your fuses. There should be a diagram on the panel telling you which fuse is for what part of the car. Link to comment Share on other sites More sharing options...
dally41888 Posted March 2, 2010 Author Share Posted March 2, 2010 all the fuses are good i checked them first Link to comment Share on other sites More sharing options...
