James Matteu Posted January 6, 2010 Share Posted January 6, 2010 Does anyone know how to remove the Power Steering Needle Roller Bearing (P/N 91021-148-004)? I have only ever delt with drawn cup needle roller bearings with open ends that literally fell out of their mounting places. The Honda power steering pump uses a simple needle roller bearing and cage assembly that appears to be pressed into the power steering pump back plate. I found this out today when I went to the salvage yard to practice tearing down the 5th Gen Accord power steering pump. All went well until I got to trying to remove the Needle Roller Bearing. When I tried to pry it out; it fell apart. I have read elsewhere on the net that forcing these types of needle roller bearings in can either damage or destroy the assembly. I may just leave the one on my car alone, but I've already spent $14 on a new needle roller bearing and would like to use it. Thanks for reading and thank you for any info you guys have. Thanks for any bumps. Link to comment Share on other sites More sharing options...
