Switching Radiator
cja3rd1983
I just bought a 1990 honda prelude si A/t :( but only has 127k i had a over heating problem and i changed the thermostat and that fixed it. But like all old cars when i went to place the upper hose back onto the radiator, part of the upper radiator broke off where the hose connects. Anyways the problem I am having is I never change one befor and i keep getting stuck on what bolts i need to take off to get the dern thing out of the car. I bought a new one as well as hoses, clamps, perfered fulids ( coolent as well as trans) new clamps. Everythiong but the heater core. Does anyone know a site that will give me step by step on how to do this.
i just did mine a couple months ago on my 89 si.... i would post some pics but that takes to long so ill give a quick instruction list
1: theirs 2 bolts holding the hood latch on(infront of the radiator) by the hood cable
2: theirs 4 bolts on each side holding the radiator trim bracket on you'll see the bolts about 6" away from your lights
3: you'll have to disconnect your fan (makes it easier to unbolt if you leave the fan on while you take the rad. out)
4: take off the bottom rad. hose
5: unscrew the trany cooler lines
6: pull the radiator out
i do believe all the bolts are going to be 10mm and the trans line is roughly a 10mm or 12mm....
P.S. its a pain is the a$$hole to get out kuz you have to twist it a bit and turn it diag. and all sorts of ways to get it out, but its a breeze to put back in. (just remember leave the fan on while you take out and put in the radiator) makes it a hell of allot easier to work with the fan that way.
Edited by xxhrdcr4lifexx
I replaced the rad on my '88 2.0L AT on 12/06. I recorded the following steps, if you still need them.
1. Last section on air intake ( mounts on radiator)
(bolts inserted back in brackets(4)).
2. Short air preheat pipe unsnapped and removed from top.
3. Side air preheat pipe unsnapped and lifted up & out with a slight twist.
1,2,3 above connect together.
4. Overflow tube unclipped from radiator and tucked asside.
5. Removed connector bracket to AC compressor and separated connectors.
6. Removed negative wire from battery.
7. separated throttle cable from rubber holder on air intake tube (Inside side)
8. Loosened bracket for air intake and swung back to side.
9. Remove air intake before filter.
10. Removed upper radiator hose and bracket between hose and
bracket spacer between AC hose and radiator hose.
11. Removed right side bolt for fan along with overflow hose bracket.
12. Removed left side fan bolt (washer + lock washer).
13. One bolt (right side) sheared on bottom, left side removed.
14. Removed radiator drain valve.
15. Removed 2 upper condenser AC fan bolts.
16. HEATWORKS electric tool used to heat left bolt to loosen it.
17. Removed right side air pipe bracket.
18. Pryed out wire holder from fan shroud.
19. Removed 2 bolts holding transmission oil metal line.
20. Removed plastic strap around lower radiator hose and right transmission hose.
21. Removed plastic connector between step 20 hoses.
22. Removed bottom hose connection to radiator.
23. Removed & replaced bolt for crossflow AC hose.
24. Separated connector ( round 2 wire) after removing from snap on brackets.
25. Removed 4 red bolts holding top of radiator and 2 red bolts in front.
( hood hold down is still viable)
26. Air director scoop for alternator cooling removed.
27. Right side upper AC hose clamp on condenser fan removed.
28. Loosened screw on right transmission oil line.
29. Removed left bolt on AC condenser fan.
30. Transmission oil hose disconnected for upper left side and plugged.
31. AC condenser fan connector tie down pushed out and connector separated.
32. Nylon clip on right fan for wire removal.
33. Removed clutch relays and brackets and left connected towards firewall.
34. Insulation on push-in "T" cut from below.
34. Right fan removed.
35. Connector on lower radiator thermostst "A" easily removed
36. Cut insulation on "T" wire push-in on AC fan wire. (X-acto knife)
37. Left hand transmission oil hose still on radiator but layed down horizontal.
38. AC fan removed straight up.
39. Radiator lifted straight up after front top crossmember bolts (6) removed
and metal tipped vertical and out of way.
40. Transmission oil line removed from radiator after hose clamp apart.
41. Radiator is Toyo (japan) # 40117
42. Removed tnermostst from radiator. tested ok.
43. Removed main water thermostst
extras left hand connector remoces by pushing out perpendicular to connector on flat catch.
X-acto knife used to remove holding tape on "T" tie downs.
ok wow are you fricken ferizzle right now's. you basically just tore apart your whole motor just to take the rad. out WOW!!!
and im prty sure he can figure out to move certain things aside to take it out kuz if your a retard and cant figure that out then you have no purpose being around a car at all nor able to drive 1.
kuz here is a basic pic of what should be done and its prty easy and ill even mark the areas for you that will have to taken apart witch is easy as turning a damn wrench....
green: upper and bottom rad. hose
red: overflow hose
white: tranny cooler lines
teal: hood latch mount bolts (4x)
orange: radiator trim piece/cover bolts (8x)
that is all your going to have to take off to get your rad. out that is it nothing else besides the fans but you can take em off when the rad. is out... if you cant unscrew the tranny lines with the fans on just take em off easy as taking a dump ok prty simple if you ask me.
not the best diagram but its the general idea that is intended there
