Li5t3d Posted September 16, 2009 Share Posted September 16, 2009 I know this is more than likely already posted on here somewhere but I looked for about an hour an couldn't find it but I have a 97 civic ex coupe and I'm swapping a dohc into it. Could I just use the stock mounts off of an SI to do the swap and if so would it be cheaper to use the stock mounts or aftermarket? And if it matters what motor I'm using i have 2 to chose from. A B18A and a B20B Link to comment Share on other sites More sharing options...
Li5t3d Posted September 18, 2009 Author Share Posted September 18, 2009 a friend today told me that i could just take the mounts off the sohc an use them with the dohc i dont think that would work but i could be wrong?? Link to comment Share on other sites More sharing options...
airjordan223 Posted September 18, 2009 Share Posted September 18, 2009 it depends which DOHC youre using Link to comment Share on other sites More sharing options...
ej6swap Posted September 24, 2009 Share Posted September 24, 2009 you could use the stock mounts on the b18 a but not sure about the b20 and also you would need the 99-00 civic si t bracket mount which is the mount bolted onto your back mount i had to do this in order for my b18a to fit into my dx hatch. Link to comment Share on other sites More sharing options...
