ttyoukno@yahoo.com Posted August 26, 2009 Share Posted August 26, 2009 my 1991 accord ex will smoke when rpm hits 4000 any ideas? Link to comment Share on other sites More sharing options...
str8jdm Posted August 26, 2009 Share Posted August 26, 2009 if its vtec motor then your vtec solinoid needs to be fixed or cleaned. samething happenes to my brothers integra Link to comment Share on other sites More sharing options...
ttyoukno@yahoo.com Posted August 27, 2009 Author Share Posted August 27, 2009 well i dont think its a v-tech but i kno the motor is a F22A4 Link to comment Share on other sites More sharing options...
ANDY_CB7 Posted September 8, 2009 Share Posted September 8, 2009 my 90 accord had the same issue, i was burnin oil like crazy. try replacing you valve seals and head gasket its alot of work but it did the trick, a cheap temp fix try gettin some stop smoke stuff from autozone see if that helps, but valve seals and a head gasket will be a very good idea Link to comment Share on other sites More sharing options...
Turtlehead Posted September 9, 2009 Share Posted September 9, 2009 my 90 accord had the same issue, i was burnin oil like crazy. try replacing you valve seals and head gasket its alot of work but it did the trick, a cheap temp fix try gettin some stop smoke stuff from autozone see if that helps, but valve seals and a head gasket will be a very good idea I have a brilliant idea....try not going over 4K rmp's if that is when it blows smoke. Link to comment Share on other sites More sharing options...
