lourod Posted August 23, 2009 Share Posted August 23, 2009 Hi 2003 civic sat 4 yrs need to get running now for daughter. installed new battery did not hear pump runing put in new pump hot wired pump works.turn key pump does not work. no elec. to pcm2 ,all fuses good ,hot wire pcm2 pump runs but car does not start. sprayed gas in engine ,runs. can not find solution please help.lost Quote Link to comment Share on other sites More sharing options...
awdpwr Posted September 22, 2009 Share Posted September 22, 2009 wires, plugs, dist cap, or the ignitor..... Quote Link to comment Share on other sites More sharing options...
cranny Posted September 30, 2009 Share Posted September 30, 2009 (edited) are you kiding me aw? why bother posting and telling someone something when you have no fukin clue what your talking about? doesnt make any sense nor help anyone. his car doesnt have any of the above items. lourod , theres a ground on the thermostat housing , 10mm bolt. take it off , clean to bare metal , replace. theres 2 grounds that go between the engine/tranny and cars chassis , do the same to them. start there. check main relay and all fuses related. Edited September 30, 2009 by cranny Quote Link to comment Share on other sites More sharing options...
cummings1017 Posted October 4, 2009 Share Posted October 4, 2009 are you kiding me aw? why bother posting and telling someone something when you have no fukin clue what your talking about? doesnt make any sense nor help anyone. his car doesnt have any of the above items. lourod , theres a ground on the thermostat housing , 10mm bolt. take it off , clean to bare metal , replace. theres 2 grounds that go between the engine/tranny and cars chassis , do the same to them. start there. check main relay and all fuses related. check your fuel pump relay, you might of fried it after jumping it. doesnt always happen but occasionally does Quote Link to comment Share on other sites More sharing options...
