Van Man Posted August 5, 2009 Share Posted August 5, 2009 Have an 03' Odyssey E-LX w/ 99k mi. Just had 100K service performed. (Inc. timing belt, etc, etc, etc) 1st issue; Second occurance. Blinker relay & hazord relay are burning out. Dealer could explain how or why this is happening. 2nd issue; Have a engine light that comes on when starting & blinks about 10x then goes out? Should it be a concern? Any assistence would be much appreciate. Thanks, John Quote Link to comment Share on other sites More sharing options...
airjordan223 Posted August 5, 2009 Share Posted August 5, 2009 if they keep burning out, im thinking its a problem with the wiring. trace the wires and see if any of it is exposed. also check your fuses check your owners manual about the flashing light, im pretty sure its in there. if its not, take it to an autozone and they will pull the code for you, which will diagnose the problem. Quote Link to comment Share on other sites More sharing options...
