civi93ex Posted August 13, 2003 Share Posted August 13, 2003 what comp. ratio will this get me if i use the thinest head gasket, or get an aftermarket thinner head gasket Link to comment Share on other sites More sharing options...
Amler Posted August 18, 2003 Share Posted August 18, 2003 I've done this setup on my wife's 95 civic, 1) your distributor will need to be modified, just opening up the front and bottom ears a little bit, 2) correct me if I'm wrong but all depending what comp. pistons you're getting if any, you could be running a compression around 9.5 to 10.5 like I said all depending on the setup you doing, also I know the Y8 heads have a much greater quench area, but not so go port flow. Link to comment Share on other sites More sharing options...
civi93ex Posted August 20, 2003 Author Share Posted August 20, 2003 just going with the stock pistons i read at ht that it would give you like 9.6:1, did this setup work out on your wifes car, im going to rebuild the head before i put it on, like new valves(maybe), new cam, new springs and retainers. Link to comment Share on other sites More sharing options...
Amler Posted August 21, 2003 Share Posted August 21, 2003 Ya the car runs great, still breaking her in, and I have this damn MAP senser problem and that's it. Link to comment Share on other sites More sharing options...
civi93ex Posted August 21, 2003 Author Share Posted August 21, 2003 does the map sensor going haywire have anything to do with the swap Link to comment Share on other sites More sharing options...
Amler Posted August 21, 2003 Share Posted August 21, 2003 I was lookin at the car tonight with a friend of mine and it started to act up and he said it sounds like something in the distributor, now that I think about if that is the problem then that would cause the MAP sensor and the stalling out to become a problem. I'm going to replace the distributor with a spare one that I have, and hopefully it will be fixed. Link to comment Share on other sites More sharing options...
