90tegx2 Posted July 14, 2009 Share Posted July 14, 2009 I have a 93 civic Si with a d16z6 recently seems to have lost power. I put just tried putting a new accel(autozone brand) ignition coil. And it still seems to bog. I checked the spark plugs and they still look pretty new. Also I bought new plug wires and put them on they made no difference so I took them back. I also just pulled the air filter off(aftermarket short ram) and soaking it in water and soap, and rinsing it. I'm gonna let it dry over night and hope that helps. Other than that I can't think of anything else besides fuel filter Being clogged? I know it's only a sohc Honda but it seemed to take off better a couple weeks ago. I have reciently had the ac evaporator and expansion valve replaced at a shop. But I don't see affecting the performance. Any imput would help thanks. Link to comment Share on other sites More sharing options...
xxhrdcr4lifexx Posted July 14, 2009 Share Posted July 14, 2009 your injectors could be getting clogged up (try running seafoam through your MAIN fuel vacuum line) and then put some in the gas tank as well that might help with the bogging down. w8 is it f/i or carbed? Link to comment Share on other sites More sharing options...
90tegx2 Posted July 14, 2009 Author Share Posted July 14, 2009 its fuel injected... I tried fuel injector cleaner...thanks for the input... Link to comment Share on other sites More sharing options...
Humphries Posted July 16, 2009 Share Posted July 16, 2009 fuel injector cleaner is different than seafoam. try it. Link to comment Share on other sites More sharing options...
