del sol daddy-O Posted June 13, 2009 Share Posted June 13, 2009 I have been looking into the mini-me swap a little bit and was wondering if the head gaskets are actually the same for these two different engines or would I need to have the gasket indicated for the z6 vtec head? I believe they should be the same but would like to make a much better informed decision when buying parts. Also, can I re-use the distributor off of my b7 with the vtec head and still use the vtec? Kinda fuzzy on this one although I have been trying to figure it out. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
project94s Posted December 7, 2009 Share Posted December 7, 2009 (edited) I have been looking into the mini-me swap a little bit and was wondering if the head gaskets are actually the same for these two different engines or would I need to have the gasket indicated for the z6 vtec head? I believe they should be the same but would like to make a much better informed decision when buying parts. Also, can I re-use the distributor off of my b7 with the vtec head and still use the vtec? Kinda fuzzy on this one although I have been trying to figure it out. Thanks for the help. Poke around on the the forums a bit theres an very nice write up/DIY on the mini-me swap floating around in there, i passed over it about a week ago. I too am going to run a mini-me setup so congrats on that decision, but yea look around a lil in older posts and check for the build thread it gives a parts list, and a step-by-step(thanks go out to the poster btw) matter of fact i was even nice and refound the thread here it is http://honda-tech.com/showthread.php?t=554053 but in relation to the the original post i just picked up a head that came off of a d16z6 to do the mini-me swap, the vtec solenoid is not there, are there any other indicators i can look for to verify that it is the correct head off the z6, the serial number on the head is a b21 number if that helps any.....i have completely disassembled the head and am about to order my valves/seals(FERREA), also ordering skunk2 valve springs and retainers...now comes to my second question is there a preferred cam to go with that you guys are using cuz i have three options comp/zex, crower, and skunk2 ne info will be helpful thanks..... Edited December 8, 2009 by project94s Quote Link to comment Share on other sites More sharing options...
