Fitron84 Posted June 10, 2009 Share Posted June 10, 2009 Thank you for stopping by, Here is the problem... My car will start and die with in 2 seconds. This ONLY happens after the car has been driven for a couple of hours or so, basically it will start just fine in the morning, runs, takes me to work, however, twiced, while trying to go to lunch i will attempt to start the car, and it will die within 2 seconds top...re started it and does the same thing...let it sit for 5 to 10min and try again and it will crank as if nothig had happened...SOMEONE PLEASE ADVISE ME...the car has never stalled on me, it only does it on the later part of the day after it has ran some... any ideas that i may want to try? i am not a mechanic by any stretch but i can turn a wrench and dont mind getting dirty. Thanks, Quote Link to comment Share on other sites More sharing options...
Kastigir Posted June 10, 2009 Share Posted June 10, 2009 I'm thinking of two possibilities here...Main Relay or the electrical portion of your ignition switch. Quote Link to comment Share on other sites More sharing options...
Fitron84 Posted June 10, 2009 Author Share Posted June 10, 2009 Main relay, thanks...i will check into it... Quote Link to comment Share on other sites More sharing options...
xxhrdcr4lifexx Posted June 20, 2009 Share Posted June 20, 2009 if you havnt figured your problem out by now, yes it could be your main relay but its most likely just your ingnition switch takin a fat dump on youi no this bcause my 89 prelude use to do the same thing til i got a new ingintion switch Quote Link to comment Share on other sites More sharing options...
