93accordwagon Posted May 30, 2009 Share Posted May 30, 2009 this is my first honda it is a 93 accord station wagon it overheats because the radiator fans dont turn on i jumped them and they do work what would keep the fans from turning on also i am a very good mechanic but know nothing about hondas , only german cars and american cars but i plan on changing that Quote Link to comment Share on other sites More sharing options...
Hatch92 Posted May 31, 2009 Share Posted May 31, 2009 sounds like a wiring or maybe a sensor issue. Quote Link to comment Share on other sites More sharing options...
s_adbell Posted May 31, 2009 Share Posted May 31, 2009 welcome to HF. Quote Link to comment Share on other sites More sharing options...
rspeach Posted May 31, 2009 Share Posted May 31, 2009 Sensor or perhaps the thermostat. NOTE: Make sure you get a honda thermostat as a Stant or Robertshaw do not work properly in Honda's. The themostat housing is located off the lower radiator hose BEHIND the distributor. Quote Link to comment Share on other sites More sharing options...
93accordwagon Posted June 1, 2009 Author Share Posted June 1, 2009 (edited) fixed ! replaced the temp sensor and switch they look alike and screw in to the block right next to each other then the fan would only come on when the car was turned off drove it around the block and it cooled down but now then therer was no a/c replaced the a/c fuse and now the fans work exactly the way they are supposed to. weird Edited June 1, 2009 by 93accordwagon Quote Link to comment Share on other sites More sharing options...
