rfkennard Posted August 4, 2003 Share Posted August 4, 2003 I own a 1995 Honda Accord EX, with a 4-Cylinder Engine. Please don't tell me to look in the manuals. I have! They all show a plug near the driver's side of the oil filter. There is a plug below the filter, which requires an allen wrench and when I removed it, I "struck" engine oil. There is a plug about 18" to the left of the oil filter, near the water pump. Oil again! Is there is or is there ain't a coolant drain plug on this engine? Thanks! Link to comment Share on other sites More sharing options...
jackasssi Posted August 31, 2003 Share Posted August 31, 2003 some are located on the front of the engine, behind exhaust manifold. 17mm i think Link to comment Share on other sites More sharing options...
carta79 Posted September 20, 2003 Share Posted September 20, 2003 There is both a radiator drain fitting and a coolant drain plug. The coolant drain plug is located on the back side of the block near the oil filter on four-cylinder models. Look for a washer and drain bolt to the left of the oil filter. Link to comment Share on other sites More sharing options...
jackasssi Posted September 20, 2003 Share Posted September 20, 2003 There is both a radiator drain fitting and a coolant drain plug. "Radiator drain" is a petcock Link to comment Share on other sites More sharing options...
