Master23 Posted May 20, 2009 Share Posted May 20, 2009 Check out some of the write ups I've completed for the S2000. Writeups include F20C engine removal and installation, cooling system, lubrication, wheel bearings, etc etc. The list of completed write ups: S2000 Brake System S2000 Cabin AirFilter S2000 Cam Chain S2000 F20C camshafts. S2000 F20C camshaft gear removal and installation. S2000 Clutch S2000 Interior Console S2000 Cooling System S2000 F20C Crank Pulley S2000 F20C crankshaft. S2000 F20C Cylinder Head S2000 F20C cylinder head inspection. S2000 F20c Engine Install S2000 F20c Engine Removal S2000 interior dash removal. Garage411.com S2000 Exhaust System S2000 F20C flywheel removal and installation. S2000 Horn S2000 Hub Assembly S2000 Ignition S2000 Immobilizer S2000 Lubrication system S2000 Interior Seats S2000 rocker arms. Garage411.com S2000 Rear Suspension S2000 Trunk S2000 Universal Joints S2000 F20C Valve Clearance S2000 VTEC solenoid test S2000 Wheel Alignment S2000 Wheel Bearing Critiques welcomed. More updates coming soon... Link to comment Share on other sites More sharing options...
Master23 Posted June 7, 2009 Author Share Posted June 7, 2009 Bumpty bump. Contributors needed asap. Link to comment Share on other sites More sharing options...
