Master23 Posted May 20, 2009 Share Posted May 20, 2009 I've completed some write ups on the Dc2 Acura Integra. Let me know if you guys see any errors. - Acura Integra DC2 B18C engine overhaul. - Acura Integra DC2 B18C1 and B18C5 Overhaul - Acura Integra DC2 B18c DOHC camshaft specs. - Acura Integra DC2 DOHC camshaft removal and installation. - Acura Integra DC2 B18C cylinder head. - Acura Integra DC2 B18c engine removal and installation. - Acura Integra DC2 fuel pressure release procedure. - Acura Integra DC2 intake and exhaust manifold. - Acura Integra DC2 oil pan removal and installation. - Acura Integra DC2 B18C front and rear oil seals. - Acura Integra DC2 B18c timing belt removal and installation. - Acura Integra DC2 B18C engine torque specs. - Acura Integra DC2 B18c valve clearance adjustments. - Acura Integra DC2 B18c valve and valve spring specs. - Acura Integra DC2 B18c water pump removal and installation. - Acura Integra DC2 B18C Valvetrain....Newly added! - Acura Integra DC2 alignment, camber, toe, caster, etc.....Newly added! - Acura Integra DC2 clutch bleeding procedure.....Newly added! - Acura Integra DC2 clutch pedal height adjustment.....Newly added! - Acura Integra DC2 Clutch assemly, master cylinder, etc.....Newly added! - Acura Integra DC2 hub and knuckly assembly.....Newly added! - Acura Integra DC2 shocks and struts removal and install procedure.....Newly added! - Acura Integra DC2 wheel bearings....Newly added! - Acura Integra DC2 front axles, damper, intermediate shaft, etc.....Newly added! More updates coming soon... Link to comment Share on other sites More sharing options...
Master23 Posted June 7, 2009 Author Share Posted June 7, 2009 Let me know if you guys see any errors. THanks. Link to comment Share on other sites More sharing options...
