Master23 Posted May 20, 2009 Share Posted May 20, 2009 Whats up guys. Here are some EG Civic DIY's that you guys might be interested in. EG Civic air conditioning. EG Civic alignment (camber, caster, toe, etc). EG Civic automatic tranny removal and installation. EG Civic drive axles. EG Civic disc and drum brakes, master cylinder, etc. EG Civic electric cooling fans. EG Civic cooling system bleeding and specs. EG Civic clutch removal and installation. EG Civic ECU. EG Civic Emissions Systems. EGR, evap, etc. EG Civic fuel system. EG Civic gauge cluster. EG Civic Ignition System. EG Civic Intake system. EG Civic manual transmission. Del Sol power windows. EG Civic power windows EG Civic Steering column. EG Civic suspension, hub and knuckly, wheel bearing, etc. EG Civic VTEC system - SOHC D series and DOHC B16A. EG Civic wiper and washer system. EG Civic valve clearance adjustments.....newly added! EG Civic idle speed and mixture.....newly added! EG Civic specs on just about everything.....newly added! More updates coming soon... Link to comment Share on other sites More sharing options...
Staninator Posted May 21, 2009 Share Posted May 21, 2009 This should probably get stickied Link to comment Share on other sites More sharing options...
Master23 Posted June 7, 2009 Author Share Posted June 7, 2009 This should probably get stickied Would be awesome. If you see any errors then let me know asap. Link to comment Share on other sites More sharing options...
