masonracing4912 Posted May 17, 2009 Share Posted May 17, 2009 i have a chance to buy gears and final drive from a gsr. i heard it will help my gearing in my 92 racecar. i run 3rd gear and i am taching 6200rpm. the guy said the differential is junk but the gears and final drive are fine. i dont know much about how it works installing these. can someone school me on this? do i need the differential? thanx for the help. Link to comment Share on other sites More sharing options...
cranny Posted September 30, 2009 Share Posted September 30, 2009 if you just want to change final drives , you need the countershaft and the ring gear off the differential. if you want to change ears as well , easy , all you need is the trees out of the GSR trans , along with the ring gear which will need to go on your diff. Link to comment Share on other sites More sharing options...
Humphries Posted December 21, 2009 Share Posted December 21, 2009 this guy will either not do anything with this information or rip apart a transmission and never know how to put it back together. Link to comment Share on other sites More sharing options...
