fifty9singlecab Posted May 11, 2009 Share Posted May 11, 2009 I purchased a 1991 Honda Accord Station Wagon off of a site and half to go and pick it up. My question is, Does it have an oil cooler? I have read where some of the 93's did and was wondering if the 91's did too. And what are the pro's of this feature. Also what motor will be in it? I think a 2.2 but not sure. And are these good engines. As always thanks for the reply's! Link to comment Share on other sites More sharing options...
James Matteu Posted May 11, 2009 Share Posted May 11, 2009 "Does it have an oil cooler?" -yes. "what are the pro's of this feature" -relatively isothermic transmission fluid conditions keeps the fluid in the correct viscosity range, which results in consistent shifting profiles. "what motor will be in it?" -If it has the motor Honda put into it, it will be an F22Ax: 2.2 liter, 16 valve, Single Over Head Cam (SOHC), multiport ProGraMmed Fuel injection (PGM-Fi); where if x=1 you have 125hp and if x=4 you have 130hp. "Are these good engines" -yes. Link to comment Share on other sites More sharing options...
