shaagsbud Posted April 11, 2009 Share Posted April 11, 2009 Hello all, new to the forums, but need a couple of confirmations. I am a mechanic by trade, though not by occupation anymore. I have a 98 CR-V that made it home one day but refused to start after that, it turns over and is getting gas as after enough cranking you can smell it. I removed the plugs for the injectors and the engine started right up and ran until all the fuel was burned out of the cylinders, now, I am not sure of anything on the crv's as I've only owned accords, and when I worked for honda, they didn't come in that often for problems. But through my troubleshooting, my guess is the ECU, unless the crv's have a injector control module seperate the ECU. And the second thing I need to know is how to recover my HP after replacing the timing belt. I made sure the timing was TDC, and every timing mark was lined up. But it is now gutless and doesn't even get out of its own way... I'm assuming I need to jump it a few teeth or something like that, to the effect that when honda puts those motors together, they set the timing some sort of funky way... Link to comment Share on other sites More sharing options...
