WEMERICKJR Posted April 10, 2009 Share Posted April 10, 2009 I HAVE A 93 PRELUDE, I SPUDERS REALLY BAD WHILE YOUR DRIVING AND ACTS LIKE ITS GETTING TO MUCH FUEL. I WAS TOLD IT WAS THE IDOIL POSTION SENSER BUT I CHANGED IT AND IT WASNT IT I DONT KNOW WHAT ELSE TO DO OR CHECK PLEASE HELP THANKS Link to comment Share on other sites More sharing options...
Turtlehead Posted April 14, 2009 Share Posted April 14, 2009 IF it does it while driving a normal speeds without heavy acceleration then I would look at something with the EGR system (possibly ports are clogged). If it is doing it under heavy acceleration post back. Link to comment Share on other sites More sharing options...
WEMERICKJR Posted April 15, 2009 Author Share Posted April 15, 2009 IT DOES IT WHEN YOU DRIVE ANYTIME AFTER 3000 RPMS IT WONT GO AT ALL IT GOES VERY LITTLE BOUT 5000 RPMS, I DID A COMPRESSION TEST ON IT AND IT ONLY HAS 180 PSI TO 190 PSI WHEN I TESTED.AND IM GETTING A LOT OF OIL IN CYCLINDER 1 PUT NEW PLUGS IN AND STARTED IT UP THEN CHECKERD PLUGS HAD A GOOD BIT OF OIL ON THEM. SO I DONT KNOW IM THNKING SHE BLOWED UP WITH THE OIL AND LOW COMPRESSION. SO PLEASE HELP Link to comment Share on other sites More sharing options...
