jseth Posted March 23, 2009 Share Posted March 23, 2009 hey guys I have a 1993 Honda civic Dx it's completely stock, mainly since its so old there is no point to do anything major. Anyway I am looking to upgrade the speakers but am having some trouble. I measured the stock speakers and they are 6inches, if I get speakers that are 6.5 inches will they still fit? will I have to do any cutting? Also for an upgraded tape deck how do I know if it will fit? do I just measure both of them and make sure they are the same? Im planning to purchase this stuff off overstock.com because they have some great deals, therefore I cant just go to a shop. any help would be appreciated, Thanks! Link to comment Share on other sites More sharing options...
Kastigir Posted March 23, 2009 Share Posted March 23, 2009 Which speakers are we talking about? Rear should be 6.5, fronts 5.25. Also, no reason you can't upgrade to a CD player while you're at it. Link to comment Share on other sites More sharing options...
jseth Posted March 23, 2009 Author Share Posted March 23, 2009 I'm just looking to upgrade the front speakers and when I went to measure them there diameter was 6 inches Link to comment Share on other sites More sharing options...
Kastigir Posted March 23, 2009 Share Posted March 23, 2009 Front speakers should be 5.25. Check the inner diameter, anything outside of the cone is irrelevant. Link to comment Share on other sites More sharing options...
jseth Posted March 23, 2009 Author Share Posted March 23, 2009 Ok thanks a lot for your help man. Link to comment Share on other sites More sharing options...
Kastigir Posted March 23, 2009 Share Posted March 23, 2009 Nevermind, I was incorrect. I got the sizes switched. Doors are 6.5, rear seat sidepanels are 5.25. Indash mounting depth is 7 1/8 inches. This is for a hatch. If you have a coupe or sedan, change it from seat sidepanels to rear deck. Link to comment Share on other sites More sharing options...
jseth Posted March 23, 2009 Author Share Posted March 23, 2009 Ok a little confused I have a sedan and I just want to replace the front speakers that are on the doors so I would look for 6.5 inches? And does the same stay true for a sedan civic 1994? Link to comment Share on other sites More sharing options...
Kastigir Posted March 23, 2009 Share Posted March 23, 2009 Ok a little confused I have a sedan and I just want to replace the front speakers that are on the doors so I would look for 6.5 inches? And does the same stay true for a sedan civic 1994? Correct. Nothing should change from 92-95. Curious as to why you don't want to change the rear deck speakers as well. Link to comment Share on other sites More sharing options...
jseth Posted March 24, 2009 Author Share Posted March 24, 2009 well the car is so old I really dont want to put a lot of money into it nor do I have a lot of money. I may replace the back ones aswell but I want to make sure I can install the front ones and see if they make a great difference. Is it difficult to replace speakers or is it just like replacing a radio? Link to comment Share on other sites More sharing options...
Sirhc22 Posted March 24, 2009 Share Posted March 24, 2009 well the car is so old I really dont want to put a lot of money into it nor do I have a lot of money. I may replace the back ones aswell but I want to make sure I can install the front ones and see if they make a great difference. Is it difficult to replace speakers or is it just like replacing a radio? ---------------------------------------------------------------------------------------------------------------------- I helped my friend install speakers into his car. I know nothing about that kind of stuff but it was a pretty easy installation. I don't think you'll have a problem installing them yourself. Link to comment Share on other sites More sharing options...
Kastigir Posted March 24, 2009 Share Posted March 24, 2009 Couple of screws, couple of wires...new speakers. Link to comment Share on other sites More sharing options...
jseth Posted March 24, 2009 Author Share Posted March 24, 2009 Ok and last thing will I need to purchase speaker harnesses or do the stock speakers have them that I can just put on the new speakers? Thanks for all of your help. Link to comment Share on other sites More sharing options...
Kastigir Posted March 25, 2009 Share Posted March 25, 2009 Depends. On my 91 Civic there were just wires. On my 91 Celica there was a plug. It's relatively simple to cut the plugs off and wire them up, but if you don't have to then why bother? If harnesses are available, go with them. Link to comment Share on other sites More sharing options...
frostedflake Posted March 25, 2009 Share Posted March 25, 2009 first off you are on the right track I have been doing honda sterio's for several years now and can do them in my sleep. all of the speakers are going to be 6.5'' front and back. you are going to need some spade terminal connectors for the speakers and a honda stereo wiring harness for the deck. as for what kind you need, all you need is a simple dimm style stereo which most are. here is an example: http://www.crutchfield.com/p_500IDAX200/Al...00.html?tp=5684 that is the size you need which most all are except navagation systems. If you need any specific instructions just send me a message and I will be happy to help you out Link to comment Share on other sites More sharing options...
