kyle9999 Posted March 12, 2009 Share Posted March 12, 2009 I am about to buy a 91 Honda prelude Si there is a transmission issue. The owner of the car just replaced the slave cylinder. This has got me stumped the clucth will not disengage. Any ideas? Link to comment Share on other sites More sharing options...
Kastigir Posted March 12, 2009 Share Posted March 12, 2009 Has the system been bled after replacement? Did they replace both master and slave? Link to comment Share on other sites More sharing options...
kyle9999 Posted March 12, 2009 Author Share Posted March 12, 2009 Has the system been bled after replacement? Did they replace both master and slave? yes he did bleed the slave cyl and only replaced the slave cyl. When you bleed the slave isnt that all you should have to bleed i am a newb on honda's? Link to comment Share on other sites More sharing options...
Kastigir Posted March 13, 2009 Share Posted March 13, 2009 yes he did bleed the slave cyl and only replaced the slave cyl. When you bleed the slave isnt that all you should have to bleed i am a newb on honda's? If he replaced it, it will take some time, and a lot of fluid to bleed. Also, it's always best to change master and slave together. Link to comment Share on other sites More sharing options...
kyle9999 Posted March 14, 2009 Author Share Posted March 14, 2009 Ok i will get him to change the master cylinder. If that does not fix it where should i go from there? Link to comment Share on other sites More sharing options...
