jfizzle88 Posted December 6, 2008 Share Posted December 6, 2008 so i have a 96 civic ex with the d16y8, and here recently when the motor is still cold while you are driving it will buck and jerk and sometimes it will die...idk if its a fuel issue or what i check for codes and its not throwing anything i tried iso heet in the gas to evaporate any water if there were any...i have been told maybe the i.a.c.v (idle-air-control-valve) but i doubt thats it, i have been told fuel pump, maybe new fuel filter, maybe even my apexi 2 v-tech controller i just need some input about what some other ppl think it could be thanks for reading and hopefully helping me out Link to comment Share on other sites More sharing options...
Kastigir Posted December 6, 2008 Share Posted December 6, 2008 Check your distributor. Had this exact issue a long time ago on my old Civic, and that's what it was. Link to comment Share on other sites More sharing options...
Turtlehead Posted December 7, 2008 Share Posted December 7, 2008 +1 ^^^ and it could be the IACV. Try spraying some trottle body cleaner through the IACV port in the trottle body. Sound more like an ignition issue, but you should check your fuel pressure and try and rule that out. Could also be a vaccum leak (worth checking for). Link to comment Share on other sites More sharing options...
03nash Posted January 11, 2009 Share Posted January 11, 2009 so i have a 96 civic ex with the d16y8, and here recently when the motor is still cold while you are driving it will buck and jerk and sometimes it will die...idk if its a fuel issue or what i check for codes and its not throwing anything i tried iso heet in the gas to evaporate any water if there were any...i have been told maybe the i.a.c.v (idle-air-control-valve) but i doubt thats it, i have been told fuel pump, maybe new fuel filter, maybe even my apexi 2 v-tech controller i just need some input about what some other ppl think it could be thanks for reading and hopefully helping me out Check the timing.My son was having issues with his 91 civic si. It would start up fine, but it had a miss in it and would idle up and down. It would also cut out, pop and crack and spit and spoutter when you would get on it..It had jumped time, so he replaced the timing belt and now it seems to be fine. I dont know to much about Hondas, pretty much old school here, but sometimes if you just at the basics youll find your problem if your lucky.Good luck Link to comment Share on other sites More sharing options...
s_adbell Posted January 11, 2009 Share Posted January 11, 2009 mine did a similar dance when the O2 sensor went Link to comment Share on other sites More sharing options...
